dme relay...and where is it
gazza
that old dme/fuel injecton relay..... have a 92 m40 cab with relay problems where is the relay i am told that its on the n/s wing but not on my car, it should be white, .....apparently that is the superceded colour it used to be orange, ....the only relay i have found that is not in the fuse box is the flasher relay where should the dme relay be does it have a k number in the fuse box
design cab and now 325 touring-
Andy335Touring
I'm not to sure where the relays are on an M40.If the car has a long black plastic ducting on the bulk head then try to look inside there,i think it just clips off ?
That's where they are on mine.
iamjj
on the m40 there is a long plastic thing running along the bulk head, directly under the windscreen.
rip it off, its properly attached.. there are two relays under there i think the white is the fuel one and orange is the dme....but could be other way round cant remeber.
You're quite right, iamjj, it is the other way around!iamjj wrote:on the m40 there is a long plastic thing running along the bulk head, directly under the windscreen.
iamjj
well i was close.
knew some clever person would point it out
gazza
right then thanks for your help .....i would never of thought it would be there.......is it a unique relay ....or is it the same as any of the others
ie if it packs up can i swap one of the others
