this part was blocked off both ends with rubber thingys, its plugged into something with a connector. but it was just cable tied to the air hose.
anyone know what it should do.? after a little goole searching i found that it is a Vapor Canister Purge Valve after i found a model number on there.
anyone know?....my car doesnt start at the mo. could this cause it?
thanks guys
