water in boot
sparky1972
Sun Oct 05, 2008 11:53 am
just found out today that there is water getting into the boot nearside pocket where the jack is stored any ideas how to cure this please
Ah, women. They make the highs higher and the lows more frequent.
Friedrich Nietzsche
gooner1
Out humping Reindeer
Sun Oct 05, 2008 11:59 am
New Bootlid rubber, sparky ,or maybe rear light gasketss.
Try pouring water around the rubber while you have the boot open and see where it.s getting in.
jamie325isport
Sun Oct 05, 2008 12:09 pm
You havent said model, if it has a aerial it could be that. My advice would be to dry it out as best you can. Chuck a bit of talc powder around then pour water all over it, that should hopefully give you a idea where its coming from.
Wanted:- One Genuine 7J Alpina. PM me
jon_d_h
Sun Oct 05, 2008 12:17 pm
Or get in the boot with a torch while some one tips water on it. I did that and there was water pissing in through the light gasket :D
DHFiS
Sun Oct 05, 2008 3:01 pm
Pull back the trim and check the drain from the aerial. I replaced mine and it solved the problem.
oakey
Sun Oct 05, 2008 3:04 pm
Aerial, rear light seals, boot seal, rear number plate light seals, or rust or rust :D Possibly a dislodged sunroof drain tube.
sparky1972
Sun Oct 05, 2008 4:07 pm
for got to say 91 4dr saloon no aerial will try suggestions though thanks
Friedrich Nietzsche
gazm3
Mon Oct 06, 2008 2:38 pm
All the above and im sure you find a cure.
Just dont allow rain near your E30. winkeye
