318is oil leak,help
delboy8000
hi all,how much oil leakage do u think it would take to be a major problem?just got car and theres a leak from somewhere down to sump plug area?any ideas?if car is sitting running,bout 2/3 drops after couple of mins.cheers guys
redrobbie
When i brought my 318iS, there was a oil leak which was caused by the bolt on the oil filter being damaged. It sprayed oil everywhere. The owner changed the copper washer and it solved the leak
Hope this helps
Hope this helps
