Fuel smell
bmben
Wed Oct 01, 2008 5:25 pm
Ive noticed the smell of fuel recently after a long trip or two inside the car, not so noticable outside. any particular fuel pipes i should check? load of petrol somehow bloody vanished aswell!!!
Ben
stonesie
Wed Oct 01, 2008 5:48 pm
Yes, the rubber fuel pipes between the fuel rail / fuel pressure regulator and the passenger side chassis rail.
Wed Oct 01, 2008 6:04 pm
few places to look
Fuel hoses under the bonnet as mentioned, the fuel filter and hoses going to it, depending on model of car the filter is sometimes on the passenger innner wing under the bonnet, on 325's often the filter is under the car, in front of the passenger rear wheel.
Finally, the hoses and pipes coming from the top of the fuel tank, lifting inspection holes under the rear seat base will reveal the top of the tank where the sender unit and pump are located, check around there for smells and split hoses
bmben
Wed Oct 01, 2008 6:58 pm
Ahh great, cheers guys, tis an IS btw. I shall have a look on the morrow with more light.
Ben
Felix79
All loved up !
Wed Oct 01, 2008 9:24 pm
Just noticed your from Oxford , another Oxford zoner to add :D
Felix79 aka Dan
E85 Z4M Roadster
bmben
Wed Oct 01, 2008 11:09 pm
Yehh! i see your from the shire aswell then? im headington area. nice lookin cabby :cool:
Ben
Black_Potato
Thu Oct 02, 2008 9:00 am
The fuel tanks also rust with age, check where the main fuel pipe from the filler cap runs into the tank, the metal spout/join on the tank can go porus.
mark_i
Thu Oct 02, 2008 10:57 pm
if you have an iS, the problem will be the short rubber fuel lines that connect to the fuel rail under the inlet manifold.
Either the line is perished or the jubilee clip is loose.
While you are looking in that area, also check the condition of the injectors.
The o-rings can leak when the engine is cold.
E30_fred
Mon Oct 06, 2008 11:54 pm
Black_Potato wrote:The fuel tanks also rust with age, check where the main fuel pipe from the filler cap runs into the tank, the metal spout/join on the tank can go porus.
I have inspected mine yesterday as there is a smell of fuel on my 316 touring, the pipe doesn't look to be in very good shape.
What are the options when it comes to sorting this out? IE can i get a silicone/rubber hose to replace the corroded metal one?
GrindCulture
Mon Oct 06, 2008 11:58 pm
mark_i wrote:if you have an iS, the problem will be the short rubber fuel lines that connect to the fuel rail under the inlet manifold.
Seems to be happening a lot now these motors are getting near the 20 year old state. Take the inlet manifold off and give the whole fuel system under there a good looking over and replace as necessary. This is one of the tasks I'm going to be undertaking in the next week or so, before it gets worse.
Not in E30s any more :(
