Heat sheild for induction kit
GDBN
Post Tue Jun 21, 2005 3:45 pm
Why not use a K&N power blanket .... ?
Don't actually know if they are any good or not but they seem to sell them together over here.
G
garyp_E30_325i
Post Tue Jun 21, 2005 5:50 pm
Got exactly the same problem mate :cry:, just bought myself some 5" Al extrusion from the plumbing dept in B&Q (it's used for air vents apparently) and I'm going to have a bash at fabricating my own cold air system, I'll let you know if it works...:?
Cloggy Saint
Post Tue Jun 21, 2005 6:26 pm
Guest
Post Tue Jun 21, 2005 9:33 pm
The B and Q air hose i have tried. The throttle response was ace. at low speeds everything was fine but i thought at higher speeds that it went a bit flat, possibly a bit lean. I also left the other panel heat shield that i made out of a sheet of aluminium in.
I have since found a couple of 10" aluminium bottles and hacked they about a bit and made quite good shield, with blow off valves so there is minimal ram effect, so hopefully air/fuel mixture stays the same.
garyp_E30_325i
Post Tue Jul 05, 2005 12:04 pm
Fitted the "B&Q cold air system", does seem to help though I can't comment about the problem Jezza mentioned ('cause my AFM is gubbed and she's running lean anyway, recon AFM on it's way...). I have pictures, if I could work out how to upload 'em...? Anyway, once the new AFM is fitted I'll get her back on the rolling road and confirm if my Ԛ£10 was a good investment!
elliot
Post Tue Jul 05, 2005 12:16 pm
im just fabbing one up out of a sheet of ally heatshield from plumbcenter, its used to go behind fires so its ideal. only cost about 3 quid n all.
