"e" or "i" cylinder head???
E30Adam
Post Sun Jan 23, 2005 6:45 pm
Which is it guys, this is supposed to be an eta engine but I was pretty sure that the eta heads had less cam bearings.
ian332isport
Post Sun Jan 23, 2005 6:56 pm
Adam,
I believe the ETA head has all 7 journals, but the Cam only has 5.
If you want to put an i cam in an ETA head, you need to drill the oil ways into the 2 unused bearing journals.
Can you see if the camshaft just passes through 2 of the journals without actually having a bearing surface on the camshaft ?
Ian.
Ant
Retired Team Member
Retired Team Member
Post Sun Jan 23, 2005 7:13 pm
Good call as always Ian.
I think you can see that from the pic Adam's posted, my eyes are not that reliable though 8)
E30Adam
Post Sun Jan 23, 2005 7:21 pm
CHeers fellas thats a relief, it looks like the actual cam has less bearings. I guess they must use the same casting for the heads on "e" and "i" engines.
It would probably be a good idea to use the eta head with an "i" cam in because it should have had an easier life no? Are the valves the same on "e" and "i" heads?
Ant
Retired Team Member
Retired Team Member
Post Sun Jan 23, 2005 7:24 pm
Eta head is 320 port sized Adam, not 100% on the valve dims, check ETK for those dude.
Tidy looking inside for sure though :cool:
E30Adam
Post Sun Jan 23, 2005 7:30 pm
In that case I thnk we'll stick with the "i" head. I noticed the inlet manifold was considerably narrower.
The iS is now ready for the new lump to be dropped in. Engine, gearbox, prop and all iS ancilliaries have now been removed. Started taking the eta engine apart just as it was getting dark. The large crank nut pretty much fell off so I think the garage where Jim got the engine might have loosened it for us which was a bonus.
Demlotcrew
Post Sun Jan 23, 2005 7:38 pm
ant wrote:Eta head is 320 port sized Adam, not 100% on the valve dims, check ETK for those dude.
Those rockers look new.
E30Adam
Post Sun Jan 23, 2005 7:49 pm
That's what I thought, they're normally stained brown like the rest of the valvetrain. Bonus!!
Andy325i
Post Sun Jan 23, 2005 8:31 pm
Hi mate,
as far as I am aware the "Eta" had 4 bearings and the "I" has seven.
I think the "Super eta" used an I head.
check this out: http://www.e30eta.com/history.htm
Kind Regards
Andy
