Hi
Bit of a problem my gauges on the instrument cluster are not workin, basically the only one that does work is the revmeter and only works when it wants to, is there a fuse i need to replace? or can someone point me in the right direction on the forum
Instrument cluster speedos???
- murran
si board batterys again........ your search button broken??
e21 killing tyres with e30 325 powerzzz
drifting on the cheap......... www.trampdrift.com
e21zone........ www.bmwe21.net
- Brianmoooore
SI board batteries can affect the tacho and temp gauge, but don't normally have an effect on the speedo or fuel gauge. No single fault that I know of gives the symptoms you describe.
Fuses for the cluster are 10, 12 and 21 ; all 7.5A.
