best engine
fuzzy
what e30? a 325 with the disc brakes all around and 51mm suspension? or a smaller engined e30 that would require the above as well as the engine?
the most common and easiest option for a power increase seems to be the m30 3.5.
GrindCulture
Bang for buck go for the M30, if you want a more "usable" car then M50, more work for less power but they're lighter and more economical. If you're feeling more adventurous build an M20 stroker, nice amounts of power and torque but not going to be cheap. Seeing as we're down the route of building a lump yourself, turbo M20? The list could go on forever, you only need to glance over the massive range of cars on here to see what can be done.
EDIT: hope you're all proud of me, not one mention of a 4 pot
Not in E30s any more
- **BANNED**
Does cost and 'originality' count? Basing a larger engine on an M20 will give a 'stock' look to the engine bay, matters to some people. Minimum cost to build a 2.7 is about £1500, those that have built a 2.8 admit to spending up to double that amount. M30 is a big lazy motor that drinks like a builder on a day out. M50 gives a non stock appearance but 192bhp,but gives a few fitting issues...read through the sticky in the engine swaps section to see if you can cope.Cost? I have just bought a donor E34 for £350...I think my biggest cost will be an exhaust manifold,I have been instructed to be sitting when I ask 'how much'....
Youth is wasted on the young.
fuzzy
cost will always be a major factor but when going down a route of unusual conversions (like mine) always expect the estimated cost to spiral, even having made allowances for possibly double the original quote.
i believe the m30 3.5 from a 535 can be done for about £600-£700 if doing most of the work yourself.
costs will rise into the several thousands for unusual or turbo'd conversions. at least with a 325 as your starting point your brakes and suspension should be good for a while before needing uprated uprated parts. my standard sized but uprated spec brakes and suspension have been good for 282bhp/ 289lbft well. it remains to be seen how well they will handle my new power levels of 330bhp.
originality is a different matter. finding a conversion thats unique and original will be a mission in itself.
think as big as you can afford to start with and consider how easy/cheap it is to tune up your chosen engine in future when the need arises.
Bob_S
cost i just put an m50b25 in my 320.. total cost? £12.74p.. the m30 is too big, too clumsy and too ancient to be a good conversion especially when m50's are sooo cheap! and being honest the m50 will make the car so much easier to drive fast it's not got a powerband which lasts 1000rpm and doesnt drink fuel like gay 12v lumpsfuzzy wrote:cost will always be a major factor but when going down a route of unusual conversions (like mine) always expect the estimated cost to spiral, even having made allowances for possibly double the original quote.
Bollocks to this 24v scrap!
- murran
but the m30 is such a mans engine! everything about it is just so masculine!
no gay vanos units, no multiple valves, no aluminium blocks.
just a heavy boat anchor torque house......
1000rpm powerband?? the torque curve is from 200rpm to 5500!!!
even the m30 engine itself knows what it is, is it ashamed, no!
you dont like the fuel consumption? worried about running costs? now thats gay!! go and buy a 3cyl polo.........
e21 killing tyres with e30 325 powerzzz
drifting on the cheap......... www.trampdrift.com
e21zone........ www.bmwe21.net
- richard-the-nutter
lolmurran wrote:but the m30 is such a mans engine! everything about it is just so masculine!
Looking for an e30 in the north east!
