AFM adjustment
e30-320i
Post Sat Jun 18, 2005 12:56 pm
just went to adjust the allen screw on the afm (marked it first so i could put it back) and noticed it is wound all the way in SHOULD IT BE LIKE THIS.i had it tuned at a local garage a few weeks ago and he told me it was underfueling so he'd adjusted the mixture. 2 days later i noticed the fuel line was split and leaking pretty badly so i fixed this, now i think its over-fueling and i'm wondering if trying to re-adjust the afm will sort it
e30-320i
Post Sun Jun 19, 2005 6:32 pm
PLEASE :roll:
Templ8e30
Post Sun Jun 19, 2005 6:36 pm
Best leave it alone and take it back to the garage. Explain to them that you found a split fuel pipe (they should really have spotted it anyway) and can they re-check and adjust it.
Best not to fiddle with the AFM unless you have the right equpment.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
e30-320i
Post Sun Jun 19, 2005 6:53 pm
yeah your probably right it just seems odd that its all the way in,and i thought if i move it it will be simple to put back where it was never mind i think i'll go to a different garage next time
thanks anyway mate...
89 325i touring
