Disk Retaining Screw
orkboss
Post Sat Jun 18, 2005 10:58 am
The allen key head screw has rounded and I cant get it off!
Is this the replacement if I try and drill it out.
GENUINE n/a 100110040 BMW DISC/DRUM BOLT SEE CATOLOGUE FOR APPL.
Disc\Drum bolt
Post Sat Jun 18, 2005 11:01 am
gonna have to get the drill out mate :cry:
think you can get away without it but I will defer to anyone else on that point
Post Sat Jun 18, 2005 11:38 am
It's not absolutely essential to fit the screw, but for what it costs, it's worth getting a new one.
Drills out easy enough, although the mechanic's quick way is, with the caliper bracket removed, to give the disc a single smack outwards with a large hammer on the side of the disc opposite the screw.
smithy318i
Post Sat Jun 18, 2005 11:45 am
Brianmoooore wrote:It's not absolutely essential to fit the screw, but for what it costs, it's worth getting a new one.
I broke my disc with that method (but it was being replaced anyway)
randomdave325
Random E30 Nutta
Post Sat Jun 18, 2005 11:54 am
hit the head of it with a similar size punch a couple of times to free the threads then hammer in a slightly larger torx bit and should undo no probs
The current fleet!
1990 318iS
1984 528ise
1987 325i sport
1990 325i cabrio
1987 m3 s50b30
'Turning money into noise' :)
Bob_S
Post Sat Jun 18, 2005 11:56 am
I have previously made a screwdriver thinner at the end wedged it in and undone it that way when it has become rounded, I usually give it a tap with a hammer to make sure it's wedged then just unscrew it. or drill it out like you have previously mentioned
orkboss
Post Sat Jun 18, 2005 12:31 pm
Hey I just used the oversized torx head and butchered it into the hole and used my torque wrench on the bit (over the top I know) and with the length of it I was able to jam it on the wheel arch thereby having both hands free one to push the torque wrench onto the bit and the other to turn the disc. Its off now. Another case of Barney Butchering.
orkboss
Post Sat Jun 18, 2005 7:46 pm
So what about removing this control arm and track rod end.
