wheres the engine code on a m20 2.5i
gorgeee
hi going to see a engine and wanted to know how do i tell its a 2.5 and not a 2.0?
Black Sport
A1BMW325iSport
its on the inlet side of the head mate at the back
telski789
also the engine number will have 25 in it instead 0f 20,23 etc.. there is also a machined 2.5 number in the exhaust side which you can see on the head in between ports
tourer-dan
So where is the actual engine number?
gorgeee
i just found the number on the head that said it was 885 so the head was defo a 325 head so i thought its pretty safe to assume the head hasnt been changed and the block is 2.5 too
Black Sport
orangecurry
wow mine has a 2.5 and a 2.7 on the exhaust manifold sidetelski789 wrote:also the engine number will have 25 in it instead 0f 20,23 etc.. there is also a machined 2.5 number in the exhaust side which you can see on the head in between ports
it might be a heavily disguised Alpina - well that's what I'm going to tell everyone anyway.... so they used the same head on the 2.7 ETA as the 2.5?
(can't see a thing on the inlet side - too many pipes)
