brakes??
stevenmurphy
Tue Aug 26, 2008 10:01 pm
looking for 4 pot calipers that could fit behind 15 inch bbs basket weaves, maybe wit the stock rotors has any one retro fitted any onto there car?? was told the 90- 93 2.3l 240 volvo ones will work wit the standered discs and wit g60 corado ones
BadDave
Sun Aug 31, 2008 9:06 am
I'd say you'd be looking for some radially mounted calipers, as opposed to lug mounted
Something along the lines of Wilwood forged powerlite wich they reckon works with a 260mm disk
£79.50+vat ea from rally design
If going the 4 pot route, it would be daft really, not to upgrade to 280mm disks at the same time
There is a 280mm kit available off the shelf
One thing to remember though, you will require wheel spacers and longer wheel bolts/conversion studs
HTH
gareth
Sun Aug 31, 2008 11:54 am
WMS 280mm 4 pots will fit inside a 15" BBS with no spacers or bodgery required
BadDave
Sun Aug 31, 2008 12:09 pm
:oops:
Completely forgot about the WMS kits
H35-24
Sun Aug 31, 2008 9:07 pm
Anyone care to give us not known to WMS a link to the companies HP?
Thanks in advance!
BadDave
Sun Aug 31, 2008 9:14 pm
H35-24 wrote:Anyone care to give us not known to WMS a link to the companies HP?
Thanks in advance!
Only thing i can suggest is drop keri-WMS a PM and i'm sure they'll provide all the info you require
