e30 318is
it has was running fine until now
was at a roundabout and i heard a sort of spluttering coming from the back i think - not too sure
it started getting worse very quick - oil light came on aswell do not know if this is related as i just had oil changed a few weeks ago.
lost alot of power
got it home - opened up the bonnet and the engine was shaking - the top part
it has also caused it to idle poorly aswell - feels like it is going to cut out but it wont.
i have just bought the car FEW weeks ago so i am very worried
please help
is it bad
johnny
please help - my engine has started shaking
I wonder if you have a misfire that is causing the loss of power and poor idle, the shaking of the engine is causing an intermitent electrical fault associated with the oil light.
First thing to do is check all plug leads are firmly attached at both ends.
hi all have checked everything as best i can
there is a smalll water leak coming from a pipe under the inlet manifold (i think - sorry) and is leaking on to the starter motor. the leak is in the middle of the pipe where it is secured to the engine i think - the leak is directly above the starter motor - however it has only leaked twice and that was just when i turned the engine on.
maybe the water is coming from somewhere else and is just appearing at this point - i dont know
i tested the ht leads by pulling each one out at a time - they all seem to be working fine but lead number 4 the one closest to the windscreen just sits in the pocket - you do not have to pull it to get it out - however it does seem to be making contact with spark plug.
i have not earthed them to check them out properly as i am not too confident about doing that.
i cant see any other leaks - but then again i am very inexperienced here.
can anybody give me some tips on how to check for leaks - sorry i know it is a stupid question.
all help is greatly appreciated
thanks
johnny
thanks
johnny
Visual inspection of all rubber hoses to begin with but some are hidden so use your hand to feel for splits. You also need to be sure everything is connected as it should be.johnnyg wrote:t
any tips for checking for leaks - i know it is a sh*t question
cheers
johnny
