fuel tank removal
chief
Post Wed Jun 15, 2005 11:55 am
i may need to remove my fuel tank
is this a tricky job , whats involved
thanks
Post Thu Jun 16, 2005 1:01 am
Remove exhaust rear section and unscrew back of propshaft and propshaft middle bearing.
Two hatches under the rear seat. Disconnect electrical connectors and pipes to the vapour tank.
Disconnect fuel hoses in the area of the rear left wheel arch.
Disconnect fuel filler hose.
Unscrew bolts and one nut supportink tank and remove.
Check/replace rear brake lines (you'll never get a better chance)..
chief
Post Thu Jun 16, 2005 5:41 pm
cheers for the tips brian
my brakelines look the titanics so yes they comin off too
Post Thu Jun 16, 2005 9:49 pm
You'll find a couple of the tank mounting bolts are a bit hidden by the rear subframe, but you can just about force on a 3/8" socket set. There's a drain plug on the bottom of the tank that you can use to drain the fuel first if you like, to make the tank lighter. Clean out the hex socket first and make sure your hex driver is fully in before you try to unscrew it.
