Steering Whining noise
Power steering pump I'd guess. Have you checked the fluid recently?
Also worth checking the belt tension.
If the pump is buggered a new (second hand) one it quite easy/cheap to fit.
Ziggy
Belt tension's usually squealy rather than whiney though...
My brother's currently replacing the leaky rack (with my spare one!) on his sheddy touring - made some right funny noises when the fluid got low!
is the noise coming from the steetring wheel or under the bonnet? the steering wheel on my e30 makes a groaning/grinding noise occasionally when turning from lock-to-lock when parking for example but no idea what it is. Sounds almost as if something somwhere needs lubricating but i have no idea what!!
- zimmerbimmer1
- BMW Parts Meister
It'll probably be the plastic bearings within the steering column needing replacingaj_mckay wrote:is the noise coming from the steetring wheel or under the bonnet? the steering wheel on my e30 makes a groaning/grinding noise occasionally when turning from lock-to-lock when parking for example but no idea what it is. Sounds almost as if something somwhere needs lubricating but i have no idea what!!
see clicky
Ahh yes - I had that in my iS...
A pikey as it sounds wd40 did the trick, I thought that it would come back quite soon cos the wd is so thin but it's been over 6 months now.
Any idea which part(s) in that diagram? realoem.com terms seem very americanised!zimmerbimmer1 wrote:It'll probably be the plastic bearings within the steering column needing replacingaj_mckay wrote:is the noise coming from the steetring wheel or under the bonnet? the steering wheel on my e30 makes a groaning/grinding noise occasionally when turning from lock-to-lock when parking for example but no idea what it is. Sounds almost as if something somwhere needs lubricating but i have no idea what!!
see clicky
Where did you squirt the WD40? Might give it a try before I think about replacing partshoshy wrote:Ahh yes - I had that in my iS...
Rkive - sorry fr the hi-jack but hopefully this may be helpful to you too??!!
- zimmerbimmer1
- BMW Parts Meister
Replace all bar number 1, 16 and 17.aj_mckay wrote:Any idea which part(s) in that diagram? realoem.com terms seem very americanised!zimmerbimmer1 wrote:It'll probably be the plastic bearings within the steering column needing replacingaj_mckay wrote:is the noise coming from the steetring wheel or under the bonnet? the steering wheel on my e30 makes a groaning/grinding noise occasionally when turning from lock-to-lock when parking for example but no idea what it is. Sounds almost as if something somwhere needs lubricating but i have no idea what!!
see clicky
Shouldn't cost more that £20 in parts
Right I am honestly a total noob when it comes to doing mechanical stuff, so could someone be kind enought to explain to me how to check the fluid level? Belt tension? and plastic bearings?
Hoshy, you mean the steering wheel centre badge? spray some wd40 there?
Any help would be appreciated because my car looks great but sounds pants!
FWD is for Pussy's
Where's the relief valve?frogman wrote:Check the power steering fluid level. If that is ok, then try adjusting the relief valve. If the noise still exists, then suspect pump.
Also, what causes tight spots in a rack?
