on board computer bulb
awighton
Mon Jul 21, 2008 9:00 pm
hi everyone!
just a quick question, prob real simple to someone who knows :) the light in my 320s on board computer isnt very bright. i can just make out the digits, but you really have to look at it (not ideal whilst driving!!) can i change the bulb and any instructions on how to do it would be good. thanks :wink:
Morat
Mon Jul 21, 2008 9:22 pm
It sounds like your backlight has gone. This is easily fixable, but a pain to get to. I'll do a quick search...
Morat
Mon Jul 21, 2008 9:26 pm
Mon Jul 21, 2008 9:38 pm
Eh, that thread's for the bulb that lights up the buttons when the sidelights are on, not the light bar!
Morat
Tue Jul 22, 2008 10:02 am
yes, and as I was about to edit my post above to include the instructions - my damn broadband crapped out :(
That thread helps you get the OBC out, once its out you just remove the lightbar by grabbing the white plastic rib saying "ziehen, pull" with some long nosed pliers and pulling it out (It's on the top right hand side of the OBC as you look at it from the front, just behind the screen). Then you either replace the blown bulb (soldering but cheap) or put in a new one from the dealer which is about £24. Your call.
itec
Tue Jul 22, 2008 1:14 pm
I had use these bulbs from Maplin
http://www.maplin.co.uk/module.aspx?Mod ... 4&doy=22m7
you will have to use two 6 volts (the orginals ore 5 volts). then just solder them in.
Total cost £1.98
Also are you aware the light switch is a dimmer switch as well.which dims thde OBC and the instrument panel
I was fooled by it :roll:
Tue Jul 22, 2008 1:47 pm
More suitable bulbs are these: Much easier to use the correct bulbs! More even distribution of light and are available from www.cpc.co.uk , part no. SC00337.
£2-35 for a packet of five, and a service life of 20,000 hours, which should be long enough for most of us. (about half a million miles!)
awighton
Wed Jul 23, 2008 11:13 pm
thanks people, wil get on it!! :mad:
