Changing bulb on OBC
AndyMack
Post Tue Jun 14, 2005 2:12 pm
Well my computer doesnt light up. Ive read the instructions for wiring one up. Is there any easy way to change the bulb that doesnt involve removing half the dash?
Cloggy Saint
Post Tue Jun 14, 2005 4:08 pm
In a word, no. If it's the display light then you can release the radio/heater panel and pull it out just far enough to get access. The bulb for the buttons is on the back of the unit and will require the panel to be pulled out further, if not all the way. Maybe someone knows an easier method...
dazleeds
old skool raver
old skool raver
Post Tue Jun 14, 2005 4:10 pm
its a twat to do :cry:
as far as i know it does have to come out
www.oldskoolfantasy.co.uk
Jamesb318is
Post Tue Jun 14, 2005 10:02 pm
If you take your stereo out you can see the side of the obc unit. You will then see a small white square, it has a rib in the middle which you can pull with pliers. Give it a tug, and you will find it moves but is stopped by a bit of plastic that juts out from the back of the dash (on the left of the white square) this bit of plastic must be destroyed!!!
It has no structural purpose etc, so either twist/break it off with pliers, just enough to get the bulb pack out, or heat up the end of a screwdriver etc and use it to melt the plastic back.
Then pull the bulb pack (white square) out, and replace the whole thing, you cant get the little bulbs seperately as far as i know
Did this yesterday on an old six series, not everything has to be hard if you can bodge it!
AndyMack
Post Tue Jun 14, 2005 10:49 pm
Jamesb318is wrote: you cant get the little bulbs seperately as far as i know
I just ordered 1 from BMW. Ԛ£20 + VAT! 8O
smithy318i
Post Tue Jun 14, 2005 11:18 pm
:lol: :lol: :lol: :lol:
Im rolling around on the floor........
Ԛ£20
is that a typing mistake ???
smithy318i
Post Tue Jun 14, 2005 11:21 pm
AndyMack
Post Wed Jun 15, 2005 2:07 am
Ԛ£20
Unfortunatly not! lol yes i am a twat! lol After i ordered them my mate said "you could just have gone to this place and got a new bulb" why didnt the tit tell me that before i ordered them???
But it pisses me off that i cant read it so its getting fixed! lol
Post Wed Jun 15, 2005 9:22 am
Replacement bulbs are available from CPC, order no. SC00337, 37p each. You need two, and note they are 5V lamps.
AndyMack
Post Wed Jun 15, 2005 12:13 pm
Brianmoooore wrote:Replacement bulbs are available from CPC, order no. SC00337, 37p each. You need two, and note they are 5V lamps.
lol ah baws!
