obc retrofit
projectmick
Fri Jul 18, 2008 12:23 am
Hi guys just a quick one
Can i fit a 13 button obc if I have an e36 m44 engine fitted, but am using the e36 loom? Is it compatible if i have the four plug adapter?
"Quattro ist fur sissies"
www.mikemasonphoto.mfbiz.com
tezk
Fri Jul 18, 2008 12:26 am
Are you using the E30 dials? The majority of the inputs for the OBC come from the dials, the others would be via external sensors...
projectmick
Fri Jul 18, 2008 12:34 am
Yeah will be e30 dials i'm using - so should be ok then?
SPADGE
Fri Jul 18, 2008 7:00 am
The obc doesn't hook-up to the engine loom at all it just plugs into the car loom so you will be ok.
projectmick
Fri Jul 18, 2008 12:55 pm
Cheers Jules, ok off I go with that now then! :D
