I was fixing a few brake lines on the car at the weekend, and now i'm having some running problems. The car is a 318iS.
The lines we changed were the long front to rear and one of the short ones at the rear.
The car is now very unhappy, it wont idle properly, missfires a lot when cold and seems very hesistant when driving in general, pressing the throttle down while crusing along will cause quite a lot of hesitation before it begins to pull, and its down on power.
Any ideas as to any specific items i should be checking that could cause these symptoms?
Stalling/Running issues
- Bobbydoughnut
Were you in the vicinity of the fuel lines/filter? Changing brake line should not affect the running of the car, you must have disturbed something while doing them
Aint white nice these days
- murran
you didnt squash one of the fuel lines running down the passengers side under the car when jacking it up did you? seen it done on a porsche boxster last week!
e21 killing tyres with e30 325 powerzzz
drifting on the cheap......... www.trampdrift.com
e21zone........ www.bmwe21.net
