help needede urgently please
markdemon
hi guys just gone to put my cabby to bed and i cant get any of the windows to close im checkin all the fuses now,has any one got any other ideas as to how i can fix this problem as i cant leave it on the rd with the windows down, not in this area where i live
thanx
92 cabby 325i
thanx
92 cabby 325i
- Brianmoooore
Is the circuit breaker pushed down?
beemerbird
Next to your hazard lights and the rear demister switch there might be a switch which (on mine) is basically blank and black with a red rim around it. This disables the window operation. This could have caused your prob
beemerbird
Good luck with it, sorry I couldn't help, but I'd wondered for ages what that switch was for on mine!!!
markdemon
yes gooner1 ive checked all the fuses,with ignition on ,and with engine running,also tried with doors open and closed,both passenger and drivers door no luck with any of it im afraid
oh sorry i never found a blown 1 either
- Brianmoooore
Do the switches light up with the doors open, or the ignition on?
The connector that goes onto the back of the circuit breaker is a bit on the weedy side, and can fall off.
- Brianmoooore
If there's nothing wrong there, the problem must centre around a blue relay at the back left corner of the glovebox area.
- Bobbydoughnut
Just a thought...How about pulling the switch out and run a live feed from say the cigarette lighter/other live to the 'up' connector on the plug just to power the motor long enough to get each window up, just for tonight?
Last edited by Bobbydoughnut on Mon Jul 14, 2008 11:25 pm, edited 2 times in total.
Aint white nice these days
- Brianmoooore
That will work, although both wires to the cut out are identical, so you'll have to find out which is the correct one by trial and error. (watch for the switches lighting up).
beemerbird
The Zone is evil. I go to bed worrying about other peoples cars.
