from what i can see the alternator has 2 wires coming from it,
one is a large one which goes to the battery and the other is a small one which probably goes to the ignition system??
i have been told that there should be three wires on the alternator??
i have a 325i on a H plate
alternator wiring??
Brenner5
320_Fizz_i
You've been told wrong.
A large red wire to the battery, via the starter motor, and a thin blue wire that goes to the ignition light. It also puts in an appearance in the diagnostic socket.
PeteE30Tourer
Moving this to the Technical Section.
