M42 - ticking sound when cold
tigerbill
Wed Jul 02, 2008 4:03 pm
Hello, on occasion, not every day, when cold there is a ticking or tapping sound when cold which gets louder with revs. It goes away after a 1 mile drive . On reading various articles I believe it to be either the timing chain tensioner or hydraulic lifters. Some Q's
1. How can you tell which it is ?
2. If lifters - is it easy to isolate which one?
3. How much will it cost to change the tensioner if it is the problem?
4. How much to change lifters if they are the problem?
5. How 'urgent' is it to get the problem fixed - am I likely to cause a bigger bill if I leave it a month for funds to build up?
thanks in advance.
aj_mckay
Wed Jul 02, 2008 5:50 pm
unlikely to be the tensioner if it goes away once the engine has warmed up. more likely to be the hydraulic tappets which will quieten down once the engine oil has been able to circulate round the engine and lubricate them - notorious on the M42 engines. you can normally hear where abouts the noise is coming from - if it's the front of the engine it may be the chain/tensioner but if it's the top it's likely to be the tappets.
most of what i've read indicates this can sometimes be helped by changing the oil, only other option is to replace tappets but that's expensive. just make sure you let the engine warm up properly if possible before using it.
Cook318IS
Wed Jul 02, 2008 5:52 pm
Or pehaps even a dodgey exhaust manifold before you go and condem the tappets! i take my iS to a bmw specialist and he's diagnosed my iS with a small hole in the exhaust manifold. And i have the same syptoms as you! IIRC its usually cylinder 1 that tends to crack. :thumb: HTH
tigerbill
Wed Jul 02, 2008 8:55 pm
thanks for th replies. I hadn't thought about it being the manifold. As a matter of interest why would a small hole create a ticking sound but only for a mile or so?
Cook318IS
Wed Jul 02, 2008 8:57 pm
As the exhaust manifold heats up, the manifold expands which "seals" any small holes up. But obviously of the hole is too big you will still get ticking noise (possibly) and it'l be louder. :D
Dave_M3
Thu Jul 03, 2008 12:16 am
Could be the injectors too...
Mine does the same but I've pin pointed the noise to around the inlet plenum and not the valve cover.
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Thu Jul 03, 2008 12:24 am
I thought mine was injectors as it really sounds likes it.. but my father set me straight - no. 1 cyl exhaust manifold as suggested above...
Dave_M3
Thu Jul 03, 2008 1:03 am
Mine only is noisy for about a minute max though, quiet from then on.
The fact that it's not fueling perfect is swaying me towards the injectors too tbh.
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Thu Jul 03, 2008 1:54 am
Sorry dave - wasn't really suggesting you were wrong - just backing up that the manifold is an option as mentioned above.
In fairness though mine only does it for a short while too cos, I'm told, that the gap closes up as the metal expands with the heat.
tigerbill
Thu Jul 03, 2008 10:31 am
Thanks guys - this is a great help.
tigerbill
Thu Jul 03, 2008 10:39 am
This is probably just my notion as well but if I start the car in the garage on the level floor and let it warm up the engine won't make the sound. However if I drive the car out of the garage and stop it with its nose facing up hill - I have an incline on the approach to my garage entrance - go away for a few minutes to close up the garage then get back in the car - start it up it is more than likely to make the noise. Not sure why parking the car with its nose facing up hill would make it do it - as I say maybe just coincidence but it doesn't do it every time which makes it a bit harder to track down.
E30GAV
Thu Jul 03, 2008 1:24 pm
hi guys. . . .i think its defo the tappets! happens to mine quite abit . more in colder weather. . . .abit tappity on start up. . .but i then leave the car to warm up before i drive her. after that shes smooth as anything. in warmer weather, when started it doesnt make tappet noise. i believe the oil is warmer therefore it gets around the engine alot quicker and lubricating the tappets etc. but ive been told its nothing major, just make sure you take care of oil on the these motors. . . especially the m42 lumps!
Cook318IS
Thu Jul 03, 2008 4:56 pm
I think i rememeber a test which was on the zone a while ago, which you could do which gives you more of a point in the right direction.
Start the car up with the bonnet open, rev fairly high so you can hear the tapping and then turn the engine off. If the tapping still occurs after the engines off it could be tappets or exhaust manifold. If the tapping stops it could be your injectors.
I *think* im right but prepared to be proved wrong!!
