Cheers.
carpet out anything i could do while its out?
- Brianmoooore
Hunt very carefully for more holes! The slightest pitting or discoloration in the panels is likely to be a rust hole.
If you see any suspects, then prod at them hard with a small screwdriver. These holes rarely improve with time, and this is a good opportunity to sort them.
- Brianmoooore
As long as the driver's side has been used with a mat, they usually do, however much they've been abused in the past.scurran83 wrote:have a new carpet!!! Wet vacuumed the old one and it came up like a brand new one.
