Help.....steam, water, bugger and arse!!!
Danstable
Post Sat Jun 11, 2005 8:26 pm
On my way to a mate's engagement party, running late, and small amounts of what seems to be steam are coming from the engine bay. Pool of what I think is water under the car, not massive loss, more like steady dripping/trickle. Slight smell to the 'steam'.
Temp guage went a bit wappy, held around the half way mark but jumped around quickly for a second or two.....odd!
Leak and steam seem to be coming from the rear end of the engine. Checked in oil filler and can't see anything resembling mayo.....yet, and the temp isn't shooting up or anything, and the coolant level looks to be fine.
Can anyone give me a clue as to what I might be facing??!
Off to borrow a car and get to Manchester, will cry later.
Dan
johnono
Post Sat Jun 11, 2005 10:50 pm
dont drive it until u can have a good look at the rad hoses and coolant bottle lines. if its a hose uԚ´re safe as.
stevo
Post Sat Jun 11, 2005 11:10 pm
sounds like head gasket :?
exhaust gasses escaping into water?
Danstable
Post Sun Jun 12, 2005 6:43 pm
It was getting a bit dark last night so couldn't see very much, and haven't had a chance to look today. I don't think it's anything to do with rad hoses as the steam/smoke was at the rear of the engine. Are there any hoses at the back end on an M20 2.5?
The smoke/steam did seem to have a slight smell to it but I wouldn't say it smelled of exhaust gasses. I'm just about certain it was water and not oil leaking, again at the rear of the engine.
Please, someone tell me there's a hose back there!
dazleeds
old skool raver
old skool raver
Post Sun Jun 12, 2005 7:02 pm
check around and under the water pump as well as there is a hole that should leak water when theres a fault with the pump
but as johnono says if in doubt dnt drive it find the fault first it might just save your engine mate good luck Daz
www.oldskoolfantasy.co.uk
Danstable
Post Sun Jun 12, 2005 7:11 pm
Yep, I'm not driving it anywhere other than 100m round the corner to the garage.
Went to have a quick look and I've a horrible feeling that there may be oil leaking rather than / as well as water. Not certain yet as I can't really move the car to see what's under it.....but there is a small amount of oil on the road infront of my car (leaked before I reversed back maybe). Could be someone elses though.
dazleeds
old skool raver
old skool raver
Post Sun Jun 12, 2005 7:28 pm
the hoses to the heatermatrix are on the bulkhead passenger side right near back of engine
have you checked them?? if lose and sucked in air will cause a whole heap of overheating probs and can kill head or gasket
tylerma
Post Sun Jun 12, 2005 7:57 pm
where abouts is the expansion tank on your car
if its at the bulkhead you might want to try another cap
because the seals can blow and then steam gets pushed out of an overflow
i had the same problem on my 318i and i replaced the cap first
because it was only about a fiver from the dealers
just had to replace the expansion tank cap on my old mans 5 series as well
because he was getting a bit of steam
and a puddle of water under the engine
its worth a try
and quite cheap
Danstable
Post Sun Jun 12, 2005 11:14 pm
Cheers fellas, I'll see what daylight presents.
Templ8e30
Post Mon Jun 13, 2005 10:30 am
Hi Dan, you're not having much luck with your motor are you mate !?
If I can be of any help just holler :D
See you soon,
Iain T
2007 Mazda 6 2.0 estate
Danstable
Post Mon Jun 13, 2005 12:57 pm
Thanks for the offer Iain. Before this latest incident I was planning on heading to my parents' place in Lymm next weekend to do some work on the car (door solenoids, LSD maybe, wiper motor, other odds and sods).
If I can get this sorted and get to Lymm then your assistance would be much appreciated if you're free.
Dan
PS Still grinning over the 2.7?!
Templ8e30
Post Mon Jun 13, 2005 11:37 pm
Going away this weekend but will be free sat 25th if that's any good ?
Yes still grinning over the 2.7 fantastically scary handling in the wet with no LSD !
What diff have you got in at the moment ? could be after a 3.91 or 3.73, the 3.64 is grumbling a bit :cry:
See you soon,
Iain T
Danstable
Post Tue Jun 14, 2005 8:28 am
I'm away on two stag do's from Monday for a week, so weekend after next is no good. Will catch up soon though.
Diff's....I have a 3.64 open diff in a box, ready to go, and I have a 3.91 open diff on the car.....which will be free when I do the swap.
I'm sure we could come to some arrangement, i.e. give me a hand at some point and you take your pick of the diffs.
Later matey.
Templ8e30
Post Tue Jun 14, 2005 10:05 am
Sounds good to me mate 8)
See you soon,
Iain T
Danstable
Post Tue Jun 14, 2005 2:15 pm
UPDATE:
The garage says its fooked. Either the head is cracked or the gasket has gone....I've posted another thread explaining in more detail what they said. Please have a look and give me any thoughts you have.
Cheers,
Dan
