Is LSD an option or standard fit on H-plate 318iS?
Toby_Unna
Boost Junkie
Post Sat Jan 22, 2005 4:41 pm
just curious, found one in a breaker but can't read the tag. think it says 4.10 but not sure.
Davenotouring
Post Sat Jan 22, 2005 4:42 pm
It was never standard fitment on the 318iS.
Ratio sounds correct, did it have an S in front of 4.10?
This would mean it's an LSD, I think you know that though, don't want to insult your knowledge!
BMW 328i Cab - Daily Slag
Toby_Unna
Boost Junkie
Post Sat Jan 22, 2005 5:06 pm
tag's hard to read, can barely make out the 4.10. had a look underneath but couldn't see the white painted S either. i was assuming it was non-slip, just checking they weren't standard fit!
Demlotcrew
Post Sat Jan 22, 2005 5:38 pm
Rotate the wheels, also you can take the Speed sensor out and shine a torch in to see the clutches.
Andrew
