BARREL HELP!!!
leeparkes
Thu Jun 19, 2008 6:15 pm
Hi
any tips on removing the ignition barrel casing,i done one on a fiesta supersport (remember them)years ago it was held on with 2 sheer bolts and i cut a slot in them and used an impact driver to get them out,
i thought it would be a similar procedure,but cant seem to see whats holding the casing on
is there a thread/link,
also are the door locks held on by fork like things
help help help
HarvyS
Thu Jun 19, 2008 6:22 pm
are you trying to change the ignition barrel? the door locks are held on by number 19/20 in the following link. a big screwdriver will remove them and the lock will then pop out with a bit of manovering.
http://www.realoem.com/bmw/showparts.do ... g=41&fg=40
ucpsale
Thu Jun 19, 2008 7:13 pm
Hello, the ignition casing has one sheer bolt facing towards the dash on the underside of the casing. Good sharp centre punch, only needs to be tapped, then there is a spring clip on the shaft of the steering colum that you need to remove, turn ignition key then pull off. Thanks
leeparkes
Thu Jun 19, 2008 8:17 pm
Thanks!!!
