rev counter
dave
Post Fri Jun 10, 2005 9:28 am
:? has anyone ever had their rev counter stop working, if so how did ya cure it cos i am totally baffled :oops:
techII sport
ian332isport
Post Fri Jun 10, 2005 9:38 am
dave wrote::? has anyone ever had their rev counter stop working, if so how did ya cure it cos i am totally baffled :oops:
Check the fuse box to start with.
It's not uncommon for it to be a simple blown fuse. This will usually take out a few other circuits as well (boot light for example).
Ian.
dave
Post Fri Jun 10, 2005 9:45 am
Ta.........thought it might be something more major than that, don't suppose you know what fuse number it is. sorry about bin a pain in the rear but i aint got a fuse box index :oops:
ian332isport
Post Fri Jun 10, 2005 9:53 am
dave wrote:Ta.........thought it might be something more major than that, don't suppose you know what fuse number it is. sorry about bin a pain in the rear but i aint got a fuse box index :oops:
Fuse 10 & 21 are the usual suspects.
Ian.
A1BMW325iSport
Post Fri Jun 10, 2005 12:27 pm
check the 3pin connector down by the ECU, there is a sleeved black wire there its the feed for the tacho.
Matt
ian332isport
Post Fri Jun 10, 2005 12:40 pm
A1BMW325iSport wrote:check the 3pin connector down by the ECU, there is a sleeved black wire there its the feed for the tacho.
Matt
Only on early cars.
On facelift models, it comes through the C101 on the bulkhead.
Ian.
Post Fri Jun 10, 2005 1:46 pm
Last case of no tacho I dealt with was a poor connection in the C101 connector following an engine change. It's a black wire, pin 9.
A1BMW325iSport
Post Fri Jun 10, 2005 5:50 pm
i`ve had many probs with the black wire
