bush on steering column
garymillscab
does any one no what it is called or part number .the bush is in the engine bay where the column connects at the bottom. it is for 1990 318i cab with power steering
ian332isport
Gary,
Are you referring to the rubber coupling in the joint that connects the steering column to the steering rack ?
Ian.
Ian.
garymillscab
yeah thats the one its realy worn and needs replacing
A1BMW325iSport
replied on your other thread dude
ian332isport
The rubber coupling is BMW part No 32 31 1 153 993.
Assuming you still have the original fitted, then it will be secured by some factory fitted rivets. To fit the new one, you have to drill out the rivets, and fit some nuts, bolts & washers. You can't use any old bolt, as they have a special shoulder to locates into the metal parts of the joint. Here are the BMW part numbers for the required parts.
32 31 1 153 995 - Bolts - 4 required
07 11 9 932 095 - Washers - 8 required
07 12 9 946 400 - Nuts - 4 required
You are looking at about Ԛ£21 for these parts from the dealer. I believe you can get the rubber coupling cheaper from ECP or GSF, but the bolts will probably need to come from the dealer.
Cheers,
Ian.
Cheers,
Ian.
A1BMW325iSport
i`ve got the compete thing inc all nuts/bolts in ex. condition
garymillscab
cheers iain thats a great help mate!
