hi
the steering on my 323i doesent seem to be up to much, standard rack feels like about 2.2 turns lock-lock! has anyone succusfully swapped a diferent rack in to an E30 and if so how much or how easy is it?
its the one thing i really fault on the car...
pants steering
Widge
http://www.e30zone.co.uk/modules.php?na ... 36rack.htm
Check that out mate, although it is a bit of work.
E30 quick racks are avalible but Ԛ£Ã”šÃ‚£Ãƒ”šÃ‚£
I think the e36 on means you can't have a 6 branch
although not sure.
Templ8e30
If you look in the articles section under technical there is a guide on fitting the e36 rack, I'll be doing this conversion myself someday when I get around to it
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
k130
Will it really make that much of a difference... seems like a lot of work!
- Homo Hair
well if you dont like the current setup then er yesk130 wrote:Will it really make that much of a difference... seems like a lot of work!
k130
true.
what does an E36 rack give lock-lock?
