Hi All
I have a cab that has an electric aeriel. I feel that when its raised, it spoils the lines of the car. Its like a giant lighning conductor.
Has anyone looked into an alternative?
The later E36 convertibles have a neater smaller one in a fixed position near the boot on the passanger side..
Thanks for any input..
Cab: Electric Aerial Alternatives.
Ziggy
Problem is that anything other than a screen mount jobbie will look out of place all the time! How about a simple switch to put it down when you're listening to something other than the radio?
cliffybabe
- Powered by Nelly
yeah dead switch the ariel unless ur listening to the radio unless its a chrome ariel
My last aerial went down if you were listening to something other than the radio
Hopefully I'll find another one of them now since I broke mine today after it was only in a month or two
Chase007
Very good there gazza i was going to use some shite flick switch wath a good idea thinking out the box heygazza wrote:i cut the feed to the ariel put a single e30 fog light switch on it and mounted it in a spare opening in the dash so i can control it myself
I have put a proper BMW switch, which cuts out the aerial, near the window switches.
I don't listen to the radio that often and the aerial whistles a bit at speed with the roof down.
G
G
I deserve 6 of the best ...
