NOOB Help refilling the cooling system 325i
Quanger
Thu May 29, 2008 3:37 am
Hi, do you refill the cooling system threw the expansion tank? And when flushing would it be a good idea to remove the thermostat so that the water can move around the system more easier? :?
siddiqi1
BFG Zone Contributor
Thu May 29, 2008 8:26 am
when refilling the system after it has een flushed would be - as you said - via the expansion tank!
you may want to have a look at this my friend:
Click here
Its in the articles section up top; should give you a few hinters and tips!
