The oil level is now about 5-7mm above the max mark on the dipstick and you get a nice cloud of blue smoke on startup which stops soon after.
Have I - I mean has he
Yes you're right.... I wondered how you could have accidentally put in half a gallon of oil?Philwild wrote:BTW, it looks like Bilun777 may have thought i said 57mm over max. It is 5 to 7 mm over so not quite that bad.
I only noticed the puff of smoke at work this morning when I started it. I assume that once some has been drained out, the extra will burn off and the
puff of smoke will dissapear?
