airflow meter tweeking
chieftouring
does any1 know if i can tweek my meter off a 2.0 to work ok on a 2.5 cheers.
psychochild187
the only tweek i know of is where you take off the top cover (black bit) and lossen the spring to make it less powerfull giving a sharper throttle response ( backfires and slows your car if u do it too much)
Andy_magic
As far as I know the 320i meter is smaller than a 325i, so you could proabably work but would need bodging to fit and then it won't run right.
lentec
- Boost Junkie
i managed to get a huge one from a jaguar to run on mine so dont see why not!
