azev-a
I think the standard is ET25, 20 might be ok but will be sticking out 5mm more than they should, 35 will need some good spacers and longer wheel bolts. You will find the offset stamped into the back of the wheel usually behind one of the spokes, it will start ''ET..''
If the offset is too far out it will knacker the wheelbearings, the rear's can be a total swine to replace too
