wheel hub grub screw removal
chief
Post Mon Jun 06, 2005 10:03 am
any tips wouls be appreciated
the grub screw which holds the disc to the hub is siezed on .
drilled it and oiled it and heated it to get the disc off which then caused the thing to turn but only the head which came off
tried the same again on the remainder but no joy
what is my options
thanks
chu346
Post Mon Jun 06, 2005 10:41 am
did you get the disc off?
psychochild187
Post Mon Jun 06, 2005 10:50 am
if you can get the disk off it should be all ok
the screw only holds the disk on in the right spot while you put the wheel on
but a pair off mole grips might do it. or hacksaw wats left and leave it.
if you cant get the disk off then get a big club hammer and hit the back of the disk . that will break the screw and then u can carry on!
TOURINGDADDY
Post Mon Jun 06, 2005 10:51 am
U bang it 8O
chief
Post Mon Jun 06, 2005 11:40 am
i got the disc off that was done with a little persuassion
the problem is the bit left in the hub needs to come out so i can put a new grub screw in
Wilson
Post Mon Jun 06, 2005 12:22 pm
chief wrote:i got the disc off that was done with a little persuassion
I wouldn't worry to much about putting a new screw in, they're not needed, they only hold the disc still to make it easier putting a wheel on., the wheel studs will hold the disc in place once the wheel is on.
SVBMW
Post Mon Jun 06, 2005 1:01 pm
If you don't put the grub screw in. Make sure the hole in the disk aligns with the broken stud.
If the broken screw stands proud it could hold the disk off at an angle
Wilson
Post Mon Jun 06, 2005 6:33 pm
SVBMW wrote:If you don't put the grub screw in. Make sure the hole in the disk aligns with the broken stud.
Good point.... Well said! 8)
psychochild187
Post Mon Jun 06, 2005 7:37 pm
if you have trouble lining the holes up for the wheel nuts, theres a tool in you bmw tool kit that does it
the one with the plastic handle
chief
Post Mon Jun 06, 2005 7:41 pm
thanks for all the help
