Wonder if its the power steering pump?
Anyone else ever had this?
I'm expecting y'all to be out there with ears to the steering wheel boss, right after you read this
if it's the exhaust gasket the noise will get louder when the engine is under load, and will also get progressively worse over time and end up damaging the manifold or head mating surfaces if not sorted.Geeman wrote:Your exhaust manifold is leaking by the sounds of it.
You can hear the noise coming up through the steering column if this happens. Two ways round it. Stick some blue-tack in the hollow end of the column when you take the steering wheel centre off and forget about it, or tighten up the manifold studs (when the car is cold) and that should solve it.
Hope this helps...
Giles.
