Right, I bought my M30 3.5 7 weeks ago, it drove fine, well, no overheating issues anyway, and a clean exhaust. Did about 500 miles with no problems and it hasn't moved since.
Parked it up and went to collect it yesterday, before starting it I checked the oil and coolant, no coolant in the expansion/header tank. So I filled that up and took the bleed screw off.
When I squeezed any pipe the bleed screw hole blew liquid so that bit had fluid in it.
Got about a mile away the temp gauge just went straight into the red.
Pulled over and the recovery man spent ages fiddling with it. We couldn't get any heat into the radiator, took the thermostat out, that was clean as a whistle but to no avail, heaters stone cold.
In the end it was towed back to mine. Are these engines tricky to bleed?
I'll flush the system tonight and try again but I just can't help thinking head gasket...
A little bit of mayo on the filler cap when I checked and last night after the 1st overheat there was steam coming out of the exhaust....
I can't afford a head gasket
