525e for a 2.7
rosscoe
Post Sun Jun 05, 2005 2:20 pm
Ihave just aquired a 525e motor from the local breakers,92000 miles for Ԛ£100. :D
Anyway,what all has to be swapped over to my 325 bottom end and is there any special machining that needs done
320Touring
Post Sun Jun 05, 2005 2:27 pm
you're better off using the 2.5 bottom end and head for the 2.7, and using the crank out of the 2.7 to increase the stroke
the 525e block has less baring shells on it and the 2.7 head is not a good design for maximum power.
you will also need 2.0 rods for the pistons as the 2.5 rods are too long
alternatively, you can drill the barings in the eta block so that they all have oil supplied and fit a 2.5 head
Jamesb318is
Post Sun Jun 05, 2005 2:37 pm
So if you wanted to make a 2.7 out of a stock 2.5 lump, you would need just the crank from the E28 525e yeah? and then the 2.0 rods, and any other custom bits etc
Then you need to take some off the top of the block to increase the c.r. right?
I know there are loads of different options for the 2.7 route, but just want to know what the most common and effective methods are - cheers
Widge
Post Sun Jun 05, 2005 3:27 pm
What you have just said James is what I plan to do. And I think it will yeild the best 2.7 short of having custom pistons made. Go for it, you need to take about 1.5 mm off the block.
chu346
Post Sun Jun 05, 2005 4:40 pm
320Touring wrote: alternatively, you can drill the barings in the eta block so that they all have oil supplied and fit a 2.5 head
Its just the 2.7 head that needs drilling not the block. The 2.7 block can be used with a 320 or 323 head and will not require drilling.
The best way to do it is:
525e crank
325 block
325 head
325 rods
custom pistons
and 325 or uprated camshaft
This way the block won't need to be machined.
Or you can:
525e crank
325 block
325 head
320 rods
325 pistons
then get the block (and possibly the piston skirts) shaved.
Geeman
Post Sun Jun 05, 2005 4:44 pm
Or you could just use a complete 525e bottom end + 320i head + 325i cam with 325i inlet manifold and a 325/327 chip.
Not the most performance gain, but the easiest and simplest.
Giles.
320Touring
Post Sun Jun 05, 2005 4:56 pm
sorry-my bad :cry: :cry:
I knew sommat had to be drilled, sorry :oops:
M5pilot
Post Sun Jun 05, 2005 6:06 pm
Id say save your money and stick a 320i head on the ETA block with 284/272 cam and spend the massive amount you save on proper tuning.
You will have a very torquey engine with good enough top end power.
Aim to get monstrous midrange and this is what will make your car a very fast machine.
200lb.ft from 2300 rpm all the way to 4500 rpm (flat torque curve) is what i had on my Alpina and that went like stink!
320Touring
Post Sun Jun 05, 2005 6:08 pm
M5pilot wrote:Id say save your money and stick a 320i head on the ETA block with 284/272 cam and spend the massive amount you save on proper tuning.
:lol: go sal! wasnt wanting to start another 320 thread :mad:
Widge
Post Sun Jun 05, 2005 6:29 pm
M5pilot wrote: 200lb.ft from 2300 rpm all the way to 4500 rpm (flat torque curve) is what i had on my Alpina and that went like stink!
Doesn't the
alpina use a 325 block head and pistons???? :wink:
Gunni
Post Sun Jun 05, 2005 6:37 pm
http://www.behindmatrix.com/e30/fotost/ ... f00080.htm
itԚ´s all there,
somebody translate that thing for the rest of us??
Gunni
@ 2012 VEMS group buy !!
dazleeds
old skool raver
old skool raver
Post Sun Jun 05, 2005 6:39 pm
http://www.appliedlanguage.com/free_translation.shtml
try that mate will def do it but only 150words ata time Daz
www.oldskoolfantasy.co.uk
