smiler
Post
Fri Jun 03, 2005 9:02 pm
Aright guys just picked up my 325i sport just wondering where the diagnostic plug is so i can put out my service light.
Also the CHECK light on the dash is flashing, when i brake and just about come to a slow stop i can hear the ABS pump buzzing just wondering if it's anything to do with it bearing in mind it has been sitting about for 8 months.
I'm a Mechanic for ford so all this BMW stuff is new to me
dazleeds
- old skool raver
Post
Fri Jun 03, 2005 9:14 pm
welcome to the zone mate should be visible in engine bay mate
im sure someone will have a pic and will know which pins reset it Daz leeds
alpinachris2
Post
Fri Jun 03, 2005 9:19 pm
hi mate ,the plug on my tech 2 sport is on the n/s front of the engine big black screw off cap (cant miss it) and the check light normally flashes ,before you test your brake lights or when a warning light on the overhead panel lights up,there is a button to cancel the flashing (check light )up on the panel aswell but it doesnt cancel the warning light ,hope this helps
JAMZ
Post
Fri Jun 03, 2005 10:16 pm
Just to jump on the thread a bit:
If you do yer own servicing and use the tool to reset yer Service lights..Does it stop em completely so they never work or does it do what it 'says on the label' and reset it till next service due?
Carl
alpinachris2
Post
Fri Jun 03, 2005 10:20 pm
jams "it does what it says on the label ",they work as normal after a reset
TOURINGDADDY
Post
Fri Jun 03, 2005 10:22 pm
Just resets till next service but that all depends on how u drive it as to how quick it comes around!!! my oil gets changed religiously every 5000 miles lights on or not
Post
Fri Jun 03, 2005 10:50 pm
Don't waste your money on a reset tool. A short piece of wire does the job just as well. You won't damage anything as long as you carefully identify the correct pin ( number 7 ) in the diagnostin socket.
smiler
Post
Fri Jun 03, 2005 10:53 pm
S'alright guys i found it. Somebody in my work gave me a shot of there reset tool so no need to buy one.
ABS is still worrying me though!!
Jos
Post
Fri Jun 03, 2005 11:51 pm
Brianmoooore wrote:Don't waste your money on a reset tool. A short piece of wire does the job just as well. You won't damage anything as long as you carefully identify the correct pin ( number 7 ) in the diagnostin socket.
And what should one do once one has located the aformentioned pin 7?
'94 e36 tree climber
TOURINGDADDY
Post
Fri Jun 03, 2005 11:56 pm
Short it to the car body,switch the ignition on, wait for the lights to go out, switch off ignition, remove wire, replace cap.
Taylor325i
- Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
Post
Sat Jun 04, 2005 12:08 am
I think your abs problem is something to do with the car sitting for a while. My track car does that all the time - for the first session on track the abs light stays on meaning no abs and the pump buzzes just as the car is coming to a halt but after the ignition is switched off and then the engine is restarted the fault disappears. E30's are good at electrics playing up if they have been idle for a while. Try driving it for a day or two and see if things improve.
smiler
Post
Sat Jun 04, 2005 10:01 am
Taylor325i wrote:I think your abs problem is something to do with the car sitting for a while. My track car does that all the time - for the first session on track the abs light stays on meaning no abs and the pump buzzes just as the car is coming to a halt but after the ignition is switched off and then the engine is restarted the fault disappears. E30's are good at electrics playing up if they have been idle for a while. Try driving it for a day or two and see if things improve.
Ok thaks. The w4ankers won't give me road tax because my i got my cover note faxed through by my insurane so another couple of days before i can drive it
