help help help
dazleeds
old skool raver
old skool raver
Post Fri Jun 03, 2005 7:01 pm
whats the quickest and easiest way to get the rear springs out???
dnt wanna undo all the back end unless i have to just want to fling in me mtec springs cheers Daz leeds
www.oldskoolfantasy.co.uk
stevo
Post Fri Jun 03, 2005 7:34 pm
im sure they can be removed with only a spring clamp when jacked up, could be wrong though :?
stevo
Post Fri Jun 03, 2005 7:40 pm
in fact i think the bottom shocker bolt has to come out, and thats it. dont forget the spring clamps though! :thumb:
Jos
Post Fri Jun 03, 2005 8:01 pm
Bottom damper bolt and the spring should pull out no problems, might need a little yank as the caps can stick to the arms/springs.
'94 e36 tree climber
Toby_Unna
Boost Junkie
Post Fri Jun 03, 2005 8:07 pm
i've never had to use a spring clamp on the back. if they won't come out easily then get someone to stand on the trailing arm to drop it as low as it will go then crowbar the spring out, sounds crude but youy won't damage anything :cool:
dazleeds
old skool raver
old skool raver
Post Fri Jun 03, 2005 8:17 pm
sweet ive done em years ago in the days of chop n drop :twisted:
had some seriously lowwwww beemers
just couldnt remember if they would come out without stripdown nice one lads thats my saturday sorted just hope she sits well with the 16s??
gonna put me old 325i shocks on too Daz
thanks all problem solved yet again thanks to the zone :cool:
Martinaston
Post Fri Jun 03, 2005 9:55 pm
What Toby said about not damaging anything you might want to read the bently manuel about changing driveshaft's and not dropping them past a certain angle because if the cv joint.
