15mpg
parkin10
Post Fri Nov 11, 2011 10:23 pm
ShepsEvo3 wrote:There is no MAF present in those pictures. The IACV has a small K&N breather type filter to stop particals getting into the IACV and the engine. So as there is no MAF, there is nothing to "meter" the air, so the fact it is unmetered doesn't matter. If there is a MAP sensor fitted to the inlet manifold, then obviously this would be affected by how much air is being let into the engine by the IACV, so in effect will be monitored.
That however looks like it is mapped Alpha N style. Nothing wrong with that unless it was turbo charged.
Make sure the TPS is working properly.
that answers my question then :?
if theres no maf then its got to throw fuel at it to run some thing like
can sort of understand 15 mpg
now that i am doing the school run evey day---
when i get to the school the engine is on the cold start still plus standing in traffic with a cold engine to get there i am getting 17--19 mpg :roll:
on a motorway run at 70--80mph it does 30--32mpg
does that sound about right to you chaps?
e301988325i
Post Sat Nov 12, 2011 6:05 pm
parkin10 wrote:now that i am doing the school run evey day---
That's normal, all running fine
I said:
e30topless said:
lock the wife in there
suchy
True Zone Relic
Post Sat Nov 12, 2011 7:56 pm
HairyScreech wrote:i assume you get a smoothly varying resistance from the throttle position sensor?
take that senor out of the "maf" and get a picture up and part number.
Will do soon as I get a morning to go fiddle, am I looking for a particular reading or just a smooth transition from open to shut?
Also I don't suppose anyone knows the readings the blue sensor should show at cold and warm (or a place where these things are listed)??
I feel this is a good place to start and trace it back to ECU. Will do the TPS at the same time and also take pictures of stuff to post up for identification!!
suchy
True Zone Relic
Post Sat Nov 12, 2011 7:59 pm
Speedtouch wrote:Any pics of the FPR - is it this type?
4 bar sounds like overkill for this engine, and may be contributing to your rich running and poor mpg. I have a spare standard BMW 325i 3 bar one, if you're interested, for a tenner posted...
Yup that's the fella. I do have a standard one knocking about I think but cheers anyway :D
suchy
True Zone Relic
Post Sat Nov 12, 2011 8:02 pm
Kool, I'll get a pic up of what is contained in that metal tube. It would be great to finally get to the bottom of this :D
suchy
True Zone Relic
Post Sat Nov 12, 2011 8:08 pm
parkin10 wrote: now that i am doing the school run evey day---
The more I think about this the more it makes sense that the blue sender isn't sending info to the ECU or it's not even connected properly to the ECU- hence constant cold start running fuel economy and more efficient when held at 4k on the motorway.
**BANNED**
Post Sat Nov 12, 2011 8:32 pm
daimlerman wrote:Check out the blue temp sensor.
Using a meter set to ohms,you are looking for a big difference in readings between hot and cold.
winkeye
Give us some readings,then!
Youth is wasted on the young.
suchy
True Zone Relic
Post Sat Nov 12, 2011 8:35 pm
winkeye
:D my memory isn't that short, I haven't had time to meddle yet!! I was just curious if there was a particular reading it should be giving- I will be following your advice Malc and will try to trace the wires back to the ECU and take readings there also :D
**BANNED**
Post Sat Nov 12, 2011 9:02 pm
Bentley says;
-10c 7000-11600 ohms
20c 2100-2900 ohms
80c 270-400 ohms
Or in easy to understand,there should be a big difference between a cold engine and a hot one.
Point about checking at the sensor AND the ECU plug is to eliminate a possible poor connection/broken wire. :D
suchy
True Zone Relic
Post Sat Nov 12, 2011 9:11 pm
Great cheers for that :D
Just so I know what to aim/look for. Does make sense the signal not reaching ECU (hence also the problem the Emerald fitter had in mapping properly!!) so is definately worth trying to trace both ends.
But will obviously do the other checks and pics at same time :D
