Only the rear two were low, when the fronts need changing I willfuzzy wrote:why not just put the same type of tyres on all 4 wheels?
Andy
To do this I would need major oversteer right? Surely having harder compounds on the rears will create more oversteer than having the harder of the two types on the front (current setup), which would cause more understeer relitively?big_jof wrote:I agree with sticking the p6000 on the back if you've had them there before, if not i'd be backing off on wet roundabouts otherwise yo'll end up looking where you've come from.
Sorry got this bit the wrong way round!andy325i wrote: If the P6000 are a harder compound (so less grip than the proxys) won't it understeer as the rear end will have more grip than the front?
not sure you have got it the wrong way round m8.Andy325i wrote:Sorry got this bit the wrong way round!andy325i wrote: If the P6000 are a harder compound (so less grip than the proxys) won't it understeer as the rear end will have more grip than the front?
Andy
