obc fitting guide
gaszman
Thu Aug 16, 2007 9:14 pm
yes its looks the same but its joined to the ind stalk with the obc ? i am dumfounded
Cloggy Saint
Thu Aug 16, 2007 9:22 pm
whatever it is, it's nothing to do with the obc and shouldn't be there!
Frenchy
Thu Aug 16, 2007 9:29 pm
The plug shown on your strut topmount is not for the temp sender is there not a "light window" top right on the OBC face maybe the lamp is used for this ?
Not really sure as i have not started to fit mine yet will attack it very shortly though as i am due an "E30 Day"
Alpina B3 3.3 Santorini Blue,White Buffalo hide with Blue Piping,Black Shadowline. No 242.
318 iS Diamond Schwarz.
Porsche 944 Turbo S,Special Order Black,Very Limited Numbers and Very Quick......;-)
slinky2000
Location: Ireland - North(Portadown) and South (Limerick)
Thu Aug 16, 2007 10:00 pm
na I certaintly dont have that bulb, I see the pic now.
that little yellow and green one I've got also and don't have plugged in either!
nickso
Fri Aug 17, 2007 2:21 am
the yellow wire is for the external heater....completely ignore it....its for our scandinavian cousins use when their cars are in danger of popping a core plug.
'88 e30 328i M52 track bint.
slinky2000
Fri Aug 17, 2007 12:07 pm
ah good man cheers :)
nickso
Fri Aug 17, 2007 3:50 pm
gaszman wrote:yes its looks the same but its joined to the ind stalk with the obc ? i am dumfounded
the extra bulb is for the tow bar setup. it flashes once when you use your indicators to confirm a signal to the towbar electrics.
gaszman
Fri Aug 17, 2007 3:51 pm
ok cheers will do one thing with it
AndyTouring
Sat Aug 18, 2007 12:51 am
darkchild wrote:The late 4 pot Lux models all had the 6 button OBC as standard.
No they didn't, at least my '93 316 Lux Touring didn't :?
Is it easy to upgrade a 6 button in my Cab to a 13 button obc & fit the 6 button to my Touring?
AndyS
Live each day as if it's your last because one day it will be.
Cloggy Saint
Sat Aug 18, 2007 12:55 am
I went from 6 to 13 button and it's much easier than starting from scratch.
gaszman
Sat Aug 18, 2007 3:11 pm
so can i just tape up the light and take the bulb out will do no harm to my car is this ok
nickso
Sat Aug 18, 2007 7:33 pm
gaszman wrote:so can i just tape up the light and take the bulb out will do no harm to my car is this ok
yes.
