Not another OBC question! Yeh but with PICS!
Royalratch
Post Fri Feb 09, 2007 4:20 pm
It took about an hour for me too.
But there is no place for the last plug into the accessory panel - am I missing something?
:x :x :x :x :x :x :x :x :x
Post Fri Feb 09, 2007 10:39 pm
Royalratch wrote: Brianmoooore said second down on the right but there's just lot's of single pin connectors - .
???? Second down on the right is power for cruise control or mirror map lights!
Post Fri Feb 09, 2007 10:49 pm
Royalratch wrote:
The strange thing is it works without the glovebox panel connector - I thought that was the power feed?
Power feed for the OBC (both 12V+ and earth) comes from the yellow connector on the instrument cluster.
Power feed from the accessories socket (2nd row from left, 2nd pin up) is for the OBC alarm horn. (CODE function).
Royalratch
Post Sat Feb 10, 2007 11:27 am
Oops! You're right Brian - I quoted you from a wrong thread. Sorry bud.
Brianmoooore wrote:Power feed for the OBC (both 12V+ and earth) comes from the yellow connector on the instrument cluster.
So if you don't need the CODE function the OBC does not need to plug into the acessory socket. Clear.
Why does the OBC clock keep resetting (after I've set it) if I don't start the car for more than 24 hours? Battery and all other electrics are fine...?
Post Sat Feb 10, 2007 1:10 pm
All you need to connect for a basic OBC installation is the connector at the back of the OBC display and the yellow connector on the instrument panel.
Never heard of a fault where the clock keeps resetting, and no idea why it's time dependant.
Suggest you do a "wriggle test" at both connectors and see if there is any disturbance.
