icv,tps bad starting..! Brianmoore!!
toughguych
Post Sat Jan 06, 2007 11:49 pm
So if the electrics for the temp sensor are faulty maybe I should try cold starting with the sensor disconnected.
Oh, I dont know, just a thought.
Had a bottle of wine now so I an't going to make much sense :mad:
As for downloading the pic:
click the link, click download for free option and wait for the code to show, enter it and the pic will appear!
Untill I work out how to post pics directly to my post.
toughguych
Post Sun Jan 07, 2007 3:04 pm
Will have to borrow a fuel pressure gauge.
Thanks for all the help everyone.
Will let you know how it goes
Post Sun Jan 07, 2007 9:35 pm
It took me a while to figure out how to download your pic! I don't recognise the part, though with it's positioning I guess it could be a vacuum-operated headlamp adjustment widget, although it may well be a cruise control thingy for all I know (never seen one on an E30 before).
Re. your starting trouble, have you tried cleaning out the ICV and throttle body with carb cleaner? Also it looks as if one of the hoses to the ICV is a tad 'bodged' if you don't mind me saying so...
kam-325i
Post Sun Jan 07, 2007 10:47 pm
The item in question is part of the Cruise control system.
toughguych
Post Mon Jan 08, 2007 7:26 pm
Yes 320SE, The pipe to the tb from the icv has a little gaffer tape on it. It only has a small crack near the icv, not enough of a worry to cause this issue I think.
Done all the bits you recomended already.
I am going to have to buy a fuel pressure tester.
I need to know if the fuel pressure should be 35-40psi?
Brianmoore, what am I looking for when I attach a t piece and crank the motor?
If I need to change the pump parts what bits do I need to buy and what bits can I salvage?
kam-325i
Post Mon Jan 08, 2007 9:23 pm
Fuel pressure should be around the 3Bar/42psi+ mark , not below.
Post Mon Jan 08, 2007 11:04 pm
toughguych wrote: If I need to change the pump parts what bits do I need to buy and what bits can I salvage?
Fuel pump assemblies have either two pipes coming out of the top or one.
If your original pump has two pipes, you need a replacement with two pipes.
If your original pump has one pipe, you can use a two pipe pump and blank off the spare one.
If your original pump has two pipes, and you can only find a one pipe replacement, then it's fairly easy to change the actual pump into your original bracket.
Don't forget that you have to remove the level sender unit (four small nuts on the top of the pump, and pull straight up) before you can remove the pump from the tank.
toughguych
Post Tue Jan 09, 2007 10:10 pm
Thanks Brian,
Mine has two pipes.
Spare parts are hard to find where I live. Prefer to by new.
I need to know what I need to change on the unit and how much it will cost from BMW.
Saw an artical on changing the motor in the pump unit. Is this all I need to change?
Cheers Mate.
Post Tue Jan 09, 2007 11:32 pm
Last one I bought from a scrapyard cost me £5 (See "brianmoooore's E30 related holiday problems"), and I think from BMW they are £200+. For that sort of money I expect it to come attached to a complete car!
Don't know for sure, but I doubt if the pump + motor is available on its own from BMW, but you might get one from Bosch.
toughguych
Post Thu Jan 11, 2007 9:51 pm
Thanks Brian
Will look about and check back in when I eventualy check the fuel pressure.
Have to get guage first.
