HID Conversion Kit A few questions
Sat Nov 11, 2006 10:02 pm
daimlerman wrote:I have dim dip on the 89 320i,but not on the 93 316i Touring.Seem to remember it was a legal requirment for a while in the 80s,the idea was that pedestrians could tell that a car showing dim dip was moving.In the days of dynamo electrics we used to run on sidelights in town to`save the battery`anyone else old enough to remember?
Isnt that why Americans call side lights 'city lights'?
stuartgallafant
Sun Nov 12, 2006 1:59 pm
aza's 320 has this half beam thing, but my iS doesnt! when i saw his lights, i couldnt worjk out what was going on with them!!
i want HID's too, but im thinking of ripping everything i need out of an X5. im gonna be bending demlots ear when it comes to do mine!!!
Sun Nov 12, 2006 2:21 pm
The problem with fitting discharge lamps in place of halogen lamps is that the reflector/lens design isn't correct, because of the different characteristics of the two light sources.
A filament source is relatively dim at the ends of the filament and brightest in the middle.
A discharge source is brightest at the ends, and relatively dim in the middle.
**BANNED**
Sun Nov 12, 2006 2:24 pm
Wow!! I reckon that I am dim at both ends!!
Demlotcrew
Sun Nov 12, 2006 6:22 pm
Brianmoooore wrote:The problem with fitting discharge lamps in place of halogen lamps is that the reflector/lens design isn't correct, because of the different characteristics of the two light sources.
why i fit real HID projectors!
Andrew
Martinaston
Sun Nov 12, 2006 6:45 pm
Are the bulbs not made longer of shorter to compensate for it ?
There is NO nucleus.
stuartgallafant
Thu Nov 16, 2006 3:41 pm
andrew, did you fit the whole lens into the E30 lamp unit?
i've got one side of X5 xenons, but im curious as to what to do with them. i'll hopefully be aquiring some more soon
Simon
Thu Nov 16, 2006 7:30 pm
There are no legal issues regarding fitting HID's to a car, only cars that have them fitted from the factory require headlamp wash wipe and headlight aim control.
As long as you get them correctly alligned, you should have no problems with the law.
carpmart
Thu Nov 16, 2006 10:39 pm
would love to see this instal as well - thanks
