Exhausts interchangeable?
**BANNED**
Post Thu Jun 27, 2013 1:49 pm
Cloggy Saint wrote:X-pipe has sleeves at both ends :?
My Hottuning manifold,one of the first UK one's,had a sleeve fitting on one pipe and an olive type fitting on the other,from what the OP is posting,H/T have modified their product....
As Gooner posted earlier,this manifold was/should be/is a straight swap for the stock mani and downpipes of a three piece system.I think that some have successfully modded a two piece system to suit,but without a lift to work on this will not be easy.
Post Thu Jun 27, 2013 8:59 pm
Be careful of ECP rear boxes, IIRC they have not listed a OE quality rear box for quite a while and their 'alternative' quality rear boxes are very alternative ! :( As in the fit is REALLY crap and the tailpipes are randomly attached and about 20mm in diameter :( :(
bmw9818
Post Fri Jun 28, 2013 6:09 pm
ive got a facelift 316, put a 325 and the pre-facelift zaust on it no issues...
Cloggy Saint
Post Tue Aug 20, 2013 3:26 pm
Still dithering over this, but it seems the easiest option would be to cut my existing down-pipes and mate them to the 6 branch manifold and not use the X pipe. Question is, is the X pipe essential or will it be ok without it?
Post Tue Aug 20, 2013 3:58 pm
Cloggy Saint wrote:Still dithering over this, but it seems the easiest option would be to cut my existing down-pipes and mate them to the 6 branch manifold and not use the X pipe. Question is, is the X pipe essential or will it be ok without it?
The general consensus is that an X pipe is desireable and deleting will cost power and torque. Something to do with equalising exhaust pulses, innit :)
Cloggy Saint
Post Tue Aug 20, 2013 4:20 pm
Hmm, is that fact or BS?
Post Tue Aug 20, 2013 6:53 pm
Cloggy Saint wrote:Hmm, is that fact or BS?
Fact !
