You should hear the solenoid click in with a loud "clunk" and the starter motor should start up and turn the engine.tom325sport wrote:OK thanks very much. Will try bridging 11 and 14 and see if it cranks!
What if it doesn't crank? Faulty starter motor?
If the solenoid does not click in and there is voltage on the small Black/yellow lead....and the engine is earthed nicely....then the solenoid sounds suspect (make sure the Black/yellow wire is on correct terminal)
If the solenoid clcks in nicely but the engine does not turn over...check that you have +12 volts on the large solenoid lug that has the lead going straight to the battery....obviously voltage should be there. If, with the solenoid clicked in there is no voltage to be measured on the other large lug on the solenoid....then the solenoids large contact inside is bad and you need a new solenoid.
If the solenoid clicks in and the starter spins but does not engage the flywheel then your solenoid is faulty or the drive gear on the starter motor is damaged or the gear is not engaging in the flywheel for some reason.
