Yea and very pleased with it tooe301988325i wrote:Monkey (Matt), CharlE30 and I have had success with that part number.
Steering rack conversion info needed (e46 330 ci sport rack)
monkey
Bristol_Jer
Got my e46 rack now, part number is 6 755 068, guess this is a newer version of the one ending in 067? It is 3 turns lock to lock. Sounds like I got the right one then
What is the standard e30 rack lock to lock, just for reference? Is it around 4 turns?
e301988325i
Wasn't that the original part number you had Matt?Bristol_Jer wrote:Got my e46 rack now, part number is 6 755 068, guess this is a newer version of the one ending in 067? It is 3 turns lock to lock. Sounds like I got the right one then
I said:
e30topless said:
lock the wife in there
e301988325i
http://www.e30zone.net/modules.php?name ... &start=225tomislav wrote:Where's the thread? i'll put it there.
Price breakdown:
Rack - £900odd + vat
Surcharge - £175 + vat
= Total was £1260!
I said:
monkey
cant remember now , i think my original e46 rack was 3 1/4 turns and the one i now have is less than 3 and feels more weighted to use . i will jack up the car tomorrow and get the number off the rack i am now using , i think it ends in 067e301988325i wrote:Wasn't that the original part number you had Matt?Bristol_Jer wrote:Got my e46 rack now, part number is 6 755 068, guess this is a newer version of the one ending in 067? It is 3 turns lock to lock. Sounds like I got the right one then
TouringMatt
Mine has the numbers;
7852 974 679
6 755 067
075367 0202
And is bang on 3 turns lock to lock (tested off car)
7852 974 679
6 755 067
075367 0202
e301988325i
Matt, don't worry, it's all in your old thread.
Bristol Jer, read this, only one page, part numbers towards the end
http://www.e30zone.net/modules.php?name ... t=e46+rack
I said:
charlE30
Interesting info MattTouringMatt wrote:Doing some research - always wise after you've spent your money![]()
Matt
+1monkey wrote:Yea and very pleased with it tooe301988325i wrote:Monkey (Matt), CharlE30 and I have had success with that part number.
Do you know what year it came from? mine was from a 2005 and ended 67. I suppose though it's irrelevant as you've got a 3 turn lock to lock rackBristol_Jer wrote:Got my e46 rack now, part number is 6 755 068, guess this is a newer version of the one ending in 067? It is 3 turns lock to lock. Sounds like I got the right one then
IIRC the E30 is around 4. something
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
Bristol_Jer
I'm not sure what year mine came from, the year wasn't mentioned in the ebay listing. It is definitely 3 turns lock-lock though. I've had a read of that link thanks, just have to wait and see what it feels like as the car is in bits at the moment!
e301988325i, I've had a read of that link, I put my part number into BMWfans and it came up with loads of models, so sure it didn't come from a sport. I'll give it a go and see how I get on
kman82
I'm thinking of doing this mod and on the look out for a cheap (ish) E46 067 rack but was wondering how easy it is to modify the linkage to fit. Is it the same procedure as noted for the e36 racks on the wiki (using an e36 lower UJ, spacer thingy to get the bolt holes to join and e30 upper UJ?) or is it now simpler than that?
Has any one had experience of fitting an E46 rack with a standard M20B25 pre facelift manifold or are there clearance issues?
I know theres tons of info on this but its all a bit confusing for a noob like me, thanks
e301988325i
The E30 linkage fits on to the E46 rack, but needs shortening.
The linkage will require modification (filing the corners down) and one of the down pipes may need a small dent to clear the UJ.
I said:
kman82
Would a danthe linkage help avoid denting the manifold?
charlE30
Dan linkage is designed to work with a couple of E34 UJ's if they have the same splines as the E30 rack then yes it would help with clearance.
I didn't have to dent my downpipe when it was fitted with the M20B25, I removed the guilbo completely and bolted the two halves together and then filled the corners down as E301988325i.
BMW F31 335d xdrive
BMW F31 335d xdrive
kman82
damn. was hoping this could be a straight swap. The filing kind of puts me off attemping it to be honest
tomislav
Hey people. The 067 rack ordered turned up today.
75quid including postage! Touch.
I'll get it unwrapped tonight and check it over and let you know how it is.
I find a grinder to be more productivekman82 wrote:damn. was hoping this could be a straight swap. The filing kind of puts me off attemping it to be honest
You shouldnt have any clearance problems TBH
kman82
good work mate, be very interested to hear how your install goes. photo thread?
charlE30
It does speed things up a bitDanThe wrote:I find a grinder to be more productivekman82 wrote:damn. was hoping this could be a straight swap. The filing kind of puts me off attemping it to be honest![]()
Seems like this years racks will be mostly E46
Dan do you know if the E34 UJ does have a different spline to the E30 rack? I'm guessing so as it bolts up to the E36 rack.
BMW F31 335d xdrive
BMW F31 335d xdrive
tomislav
Unwrapped therack, all seems in good order so excellent news.
3 turns lock to lock, 067 part number.
I'll keep this thread updated with the install when it happens. next couple of weeks
E30, E36, E46, Z3 etc have the same rack input shaft spline
E30 manual rack has a different spline
The E30 column spline is different, just means the UJ has to be rebuilt with the top half of the E30 linkage.
Just to add, I have an E46 rack on my chromie, no cooler pipes at all, loads of go and stop power and never had any overheating problems even in the hottest summer weather in the welsh mountains at full chat.
Track car is the same but with E36 rack, again, never had any problems from not running a cooler pipe.
I dont intend to fit any cooler pipes to the track car unless I experience problems
charlE30
tomislav wrote:Unwrapped therack, all seems in good order so excellent news.
Cheers for the useful info Dan
BMW F31 335d xdrive
BMW F31 335d xdrive
tomislav
Waitingon the second front subframe from bmw-mad on the zone.
He sent me one a couple of weeks ago but it was in the boot of my astra when it got stolen
I haven't got a photo bucket account yet so posting pics may be difficult but i'll update as and when i can.
I'm a mechanic anyway so hopefully i can figure most of the sh1t out for myself.
All input so far has be gratefully recieved, thanks people.
kman82
Just wanted to quickly check this as mines going in the garage to be done in a couple of weeks. I have read elsewhere that you should use the rear holes for mounting the rack (same as currently used by PAS rack). Is that right?charlE30 wrote: Use the forward mounting holes with the same spacers as used on the E36 rack swap, as far as I'm away there are no guides as it's so simple.
